M
melodymwah
hi, im a student, and struggling with some questions that i cannot find an answer to:
1. If on filling in an eic and there is no info on the main service fuse (type/rating what should you do?
2. If main tails are not 25mm do you HAVE to upgrade them before carrying out any work?
3. Similiarily if main earth is not 16mm and main bond is not 10mm MUST this be upgraded first before carrying out any work
4. Also how would you split tails into a henley block?
5. How comes to run a seperate circuit for a 400w fridge, would you use a 20a radial when fridge only needs 2a
