MisterProzilla
Hi,
I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with a mains/mixer. I had bought an inline fan and a separate humidistat/run-on timer module with the idea that it could be installed using the old electrical shower wiring; my intention was that the wiring would go into the humidistat then onto the fan, so it's always live (with an isolator if needed), detecting moisture and turning on as needed without needing to switch it on manually via the lights or a separate pull switch.
Instead the electrician has installed it on the lighting circuit, saying that regulations require bathroom vent fans to be wired via the lights. I can't find any info about this -the humidistat is now effectively useless as I have to turn on the lights when I want the fan to run. Does anyone know of these regs and can you point me to them?
I'm in the UK by the way!
Thanks for reading
Thanks for reading
- TL;DR
- Do UK regulations require wiring bathroom ventilation via lighting circuit?
