Guest viewing is limited
View the thread, titled "Bathroom light fitting with no joist to fix it to" which is posted in UK Electrical Forum on Electricians Forums.
G
GMjohn
Hi,
I'm changing out 6 downlights in the bathroom as they don't work very well and was going to change it for one ip44 rated bathroom light fitting which takes 1 es bulb. The fitting has a 32cm diameter approx, with a glass cover. However, when I took the downlights out, I noticed it was a false ceiling with plasterboard attached to wooden supports, and there was no wooden support near where I was going to put the new fitting. I cannot get access from above to fit another wooden support for the light to fix into, so was wondering what my options are.
On the spot, I could think of two possibilities, but don't have the experience to know if they'd be safe ones. The obvious would be to use plasterboard fixings like spring toggles, but I have no idea whether that would be suitable for holding the weight or whether the plasterboard is at risk of being pulled down at some future point. I have also considered whether I could shove a length of wood up through one of the existing downlight holes, screw through the plasterboard to hold it in position, and fix the fitting into this. I guess this would give something to screw into and spread the weight a little, but would it serve the purpose and be safe?
Is there a way to fix this fitting to the ceiling safely without putting a noggin up there to screw to? Or is my only real option to refit downlights?
​done htis a few times. as long as the fitting is not too heavy, should be OK.
My advice is to forget the es lamp fitting, old fashioned and outdated, get a 18 watt led round bathroom light, they weigh next to nothing and costs are now very competitive.
and don't forget to power the light ( and the fan) from the shower.:willy_nilly:
Reply to the thread, titled "Bathroom light fitting with no joist to fix it to" which is posted in UK Electrical Forum on Electricians Forums.
