View the thread, titled "Bathroom light fitting with no joist to fix it to" which is posted in UK Electrical Forum on Electricians Forums.
G
GMjohn
Hi,
I'm changing out 6 downlights in the bathroom as they don't work very well and was going to change it for one ip44 rated bathroom light fitting which takes 1 es bulb. The fitting has a 32cm diameter approx, with a glass cover. However, when I took the downlights out, I noticed it was a false ceiling with plasterboard attached to wooden supports, and there was no wooden support near where I was going to put the new fitting. I cannot get access from above to fit another wooden support for the light to fix into, so was wondering what my options are.
On the spot, I could think of two possibilities, but don't have the experience to know if they'd be safe ones. The obvious would be to use plasterboard fixings like spring toggles, but I have no idea whether that would be suitable for holding the weight or whether the plasterboard is at risk of being pulled down at some future point. I have also considered whether I could shove a length of wood up through one of the existing downlight holes, screw through the plasterboard to hold it in position, and fix the fitting into this. I guess this would give something to screw into and spread the weight a little, but would it serve the purpose and be safe?
Is there a way to fix this fitting to the ceiling safely without putting a noggin up there to screw to? Or is my only real option to refit downlights?
Reply to the thread, titled "Bathroom light fitting with no joist to fix it to" which is posted in UK Electrical Forum on Electricians Forums.
