Bathroom light pull switch variants? | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Bathroom light pull switch variants? in the UK Electrical Forum area at ElectriciansForums.net
UK West Mids
are the older switches where the whole cowl hand turns onto the base framework with the switch on, still available (the ones like a ceiling rose about 80mm across)? or are they now none regulation?
All the MK and Crabtree switches i can see are 2 part with a huge pattress box onto which the switch part is fixed with 2 screws.
I ask because I very much doubt i could pull through enough wire to fix to this new setup should i need to replace another one.
Reply to Bathroom light pull switch variants? in the UK Electrical Forum area at ElectriciansForums.net
Been quoted £120 +materials To sort wiring and wire to extractor fan What do you all think on that price ? The electrician lives 1/2 mile away
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
Recommended Sponsor News
Hi everyone,
