bathroom light question/boiler earth bonding | Page 2 | on ElectriciansForums
Discuss bathroom light question/boiler earth bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
you need to brush up on your coding IMHO
Some bedtime reading for you!
https://www.----------------------------/mediafile/100404922/Best-Practice-Guide-4-Issue-4.pdf
im still learning, by no means an expert on the regs lol, still just a 3rd year :D, like learning to drive it is only when you go out on your own that you really learn, the more i read over the regs its definitely a c3 offence.
as a rule of thumb if a room contained a bog it got a waterproof light fitting when doing inspections, at least on the council contracts at my last job
In which case why isn't your boss checking all this?
Do you mean something like this?
i mean that the pipes should be earthed internally to the earth terminal inside the boiler itself so no real need for bonding with tags and cable
the light fittings may come down to a matter of opinion over what is "suitable" as i did not measure the height of the lowest point of the pendant from the ground
You need to understand why we require to protective bond pipework, extraneous parts etc, then you will understand why it’s usually unnecessary at the boiler especially in the case you’ve described.
ive always thought that , but as an apprentice i was told to bond them anyway, i think my boss at the time was just learning 17th edition regs himself as he came from a maintenance background and had just started up on his own doing domestic, he was good though, maybe a bit overly cautious when it came to earthing.
im up to speed on most things, just now im doing the paperwork side of eicrs im finding new things i need to learn that i missed at college/wasnt taught in the first place lol.
got my FICA in january and been offered a lead electrician position at my work so will need to brush up on the regs im unclear on pretty sharpish
battens, snub = short
Previous Regulations allowed batten holders providing they had an HO (Home Office) shield fitted which helped prevent condensation dripping on the lamp. Light fittings must not only be suitable for the zone but also for it's location if not installed in the prescribed zones. Only you can decide that.
another mistake i made was thinking the zones extended all the way to the roof, not only to 2.25m
That may be the case but the fittings still need to be suitable for the location and environment. Moisture and splashes don't care about the zones and will go anywhere is damn well pleases...
I have four young kids and regularly have water dripping off the bathroom ceiling which is above 2.25m.
They do normally with a metal clamp to secure all incoming pipework.
I thought it was called Home Office Skirt, suppose that's sexist nowadays :)
Reply to bathroom light question/boiler earth bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
