bathroom light | Page 2 | on ElectriciansForums
New Zealand bathroom light
Discuss bathroom light in the UK Electrical Forum area at ElectriciansForums.net
To 17th, supp. bonding is required unless all circuits meet the required disconnection times, and an RCD is installed, and all extraneous-conductive parts in the location are connected by main protective bonding conductors to the MET, so you would argue it is "potentially dangerous" (C2).
To OP, I think C2 as it is "potentially dangerous".
I was always taught:
-Code 1 if there is a danger and a fault
-Code 2 if there isn't a fault but it'd be dangerous under fault conditions
-Code 3 if there is no danger or fault but isn't compliant to latest regs
Does that mean that all those installations done before 16th are dangerous because they had no 30mA RCD or supplementary earthing?
Something that was installed under a previous reg & was ok at that time can not becombe potentially dangerous over night. This would be a C3 IMO no more, no less.
Regarding why would the reg change they do that all the time. once upon a time you had to earth bond a stainless steel kitchen sink & all sinks came with little tag to fix your earth cable to, then over night they stopped fitting the little tag & earthing was no longer required so what was that all about.
Reply to bathroom light in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
