Bathroom lighting and fan query...!! | on ElectriciansForums
Discuss Bathroom lighting and fan query...!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
mgzr
ok so any help would be greatly received..!
just finished a rewire on a bungalow...
the new owners of the property are planning to do the kitchen and bathroom in the summer, so i've reused the old shower and cooker supplies and kitchen ring and put them away in the new board for the time being...
the bathroom had an existing 2 gang switch on the outside (fed with a 3 core twin and earth) which separately switched the lighting and inline fan... fully aware there is no triple pole isolator for the fan, but will certainly be fitting one further down the line...
i rewired the feed to the bathroom, to an adaptable box (fitted with din rail) and connected the feed to the red core of the 3 core down to the switch and used the blue as the switch wire for the fan and yellow for the switch wire for the lights....
a fairly straight forward switching set up etc....
when the circuit is energised the lighting switches correctly on and off, but as soon as i switch on the fan, the lights go out..?!?
oh and the fan was fed with an existing 2 core twin and earth, so no permanent feed just a switch wire and neutral....
any ideas anyone..!!
thanks in advance....
carried out r1+r2 and insulation resistance...
everything came back ok...!
the bathroom feed is an end of line....
come the summer, when the customer decides to rip the old bathroom out, i fully intend to install a fan isolator and will keep the light switch in the original place (hall side of the bathroom door) and fit a 1 gang purely for the lighting.
just seems bizarre......
thanks for the input..!!
Have you got a photo of the connections in the switch and your connections you made in the adaptable box you can post up?
unfortunately not....
the feed to the switch (red core) is linked out across the 2 commons of the 2 gang switch...
and the switch wires (blue and yellow) are connected to the out going lives (in the adaptable box) for the lighting and fan respectively....
i'm pretty dam sure the connections are correct...
initially thought something very similar, however i checked my connections and everything was ok...
the neutral connection at my adaptable box, contains the neutral in, and both the neutral for the lights and neutral for the fan....
Back to basics then, and check wiring & connections. Perhaps draw out your design, make sure your not making a mistake. Can only think it's something simple?
the yellow switch wire (for the lighting) remains live when i throw the switch for the fan....
but lights go out...?!?! so initially i also thought perhaps it was loosing its neutral somewhere...
Remote possibility and clutching at straws but we are all capable of silly things on occasion
Is it possible that you have assumed each gang is oriented as you believe and one of them is the other way
so you're saying potentially the live feed goes into one of the switches on the common and links across to the other switch on the 'L1' terminal...?!
shouldn't make a difference......?!?!
It is odd the light turns on with one switch but goes off when the fan is switched especially when you have a solid link at the live feed.
Reply to Bathroom lighting and fan query...!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
