Bathroom lighting and fan query...!! | Page 2 | on ElectriciansForums
Discuss Bathroom lighting and fan query...!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
out of interest, i doubled up both switch wires (blue and yellow) on one switch, and re engergised the circuit. this time around, the lights didn't work at all but the fan operated with the switch....
so you're saying potentially the live feed goes into one of the switches on the common and links across to the other switch on the 'L1' terminal...?!
shouldn't make a difference......?!?!
No,if you have your link in L2 instead of off the feed in the common , you have a simple changeover
I was just suggesting that silly mistakes can and do occur,it seems to me this thread almost definitely suggests a changeover and there is only one place that is going to occur
i can see your thinking....
however, i can throw the light switch and the yellow become live (230v - and lights come on) then throw the fan switch and the blue becomes live and fan starts up but yellow switch wire remains live but lights go out......
If the wiring was as per dwg then there wouldn't be this problem, I think.
This is what I don't understand the live feed is solid between the switches and as long as one is in common and the other L1 or L2 the other switch should have no affect on it. Effect or affect, I never know :mad:
Still think somehow, you are introducing a voltage at the lights neutral, when turning on the fan. Think you just need to check all your connections are correct.
Guessing from afar, what should be the light neutral is actually connected to the incoming unswitched live.
If your connections are correctly positioned then the only thing I can think is to check is that neutral connections on the DIN rail are correctly connected, if one (probably the incoming) were only just in contact then it may not be able to carry the current of both items, however this would be an extraordinarily precise partial disconnection.
I woudl tend to go for a wiring error myself, check continuity when the circuit is dead to see what you get in different switch positions and see if you have continuity along cores between points.
Reply to Bathroom lighting and fan query...!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
