Bathroom Lights on RCD | on ElectriciansForums
Discuss Bathroom Lights on RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
wolfboy
Hi
Having looked at previous posts just after some clarification.
If i am replacing a bathroom light like for like i don't need to put on an RCD?
If i am replacing one bathroom light with 2 or 3 IP rated spotlights i have to put on RCD as i have altered the circuit?
Cheers
If i am replacing a bathroom light like for like i don't need to put on an RCD? agreed
If i am replacing one bathroom light with 2 or 3 IP rated spotlights i have to put on RCD as i have altered the circuit? i would as i'd be supplying a MWC with my signature on it. CYA
No not correct IMO, RCD protection for all new bathroom equipment installed.
are you sure? "additional protection shall be provided for all low voltage circuits". So not ELV then ;)
If the lights in the bathroom are now SELV I can't see any practical reason to demand the LV circuit is RCD protected.
A grey area IMO regarding Selv
I agree. I guess my approach is that, if I am installing a new bathroom light circuit then I would RCD protect it, SELV lights or not. However if I was adding SELV lights to an existing circuit I would not insist on adding an RCD.
Surly it depends on if the bathroom has adequate supplementary bonding. If so then no you don't need to RCD protect but if not then the regs require all circuits in a bathroom to be protected by a 30mA RCD. As you are making an alliteration to an existing circuit that circuit must be left by you up to the current regulations as you take responsibility for that circuit.
I think you might have that the wrong way round.......
Reply to Bathroom Lights on RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You too? I thought I was in a unique position:anguished::coldsweat:
šŸ˜„ It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
