Bathroom Zones | on ElectriciansForums
Guest viewing is limited
Discuss Bathroom Zones in the UK Electrical Forum area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Guys
Just seeing what others think please.
Got a bathroom light switch and not sure if 'out of zone' or can classed as 'zone 2' ?
Originally switch was outside bathroom but doorway has moved since.
Is going to be bit of pain to move at this stage so one this occasion hoping it may be in zone 2.
Did try Niceic helpline and not so helpful this time.... send in plan and hopefully get reply back in 5 days.
See what you think of attached.
Thanks Sy
[ElectriciansForums.net] Bathroom Zones
PIR wall sensor IP rated for zone 2 ...one possible example....
..........could be set for 5 mins so persons could have a quick shower or wave outsize zone1 for a longer soak !!!
Reply to Bathroom Zones in the UK Electrical Forum area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
