T
tillyhouse
Hi all, I have recently moved a second bathroom and have a couple of questions. The earth bond wire from the old bathroom is buried into the wall and has about 6 foot exposed into where the old bathroom was, can I just cut this off or can I extend it to bond the new bathroom which is a further 15feet away? I will be installing a 10.5kw electric shower on a 30a rcd does this need a supplementary bond? I will also be installing a water heater on its own circuit as I cant pipe hot water to this location, will this need to be supplementary bonded?. As far as I can make out the bonding wire will go back to the main consumer unit, but there is a separate consumer unit that served the old bathroom and kitchen (basically an annexe that is connected to main house) I also cannot seem to find any bonding to mains water etc. We have only just moved here, many thanks, Steve
