battery drain help needed
Having starting problem with my car.some one advised it was the solenoid o the starter motor this controls the current into the starter motor..could this be the problem?the solenoid sits on top of the startermoter.a new one would come with its own solenoid!reconditioned ones are thought too work fine!cheers
