BBC1 now Fake Briton and CABLE!! | on ElectriciansForums
Discuss BBC1 now Fake Briton and CABLE!! in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
What is interesting Mark ?
Well I am thick on the uptake
[ElectriciansForums.net] BBC1 now Fake Briton and CABLE!!
I thought it was something you may have seen, but forgot to include in the post
the fake fp200 looks exactly the same as the real one and you could only tell the difference once is on fire...
little too late by then
anybody had major grief with dud cable
i bought a roll of high-impedance bell wire onetime
had 10 houses done before i realised
serves you right for wiring a ring final in bell wire.
Right that's its, from now on I'm only getting my cable from the big orange shed because all their stuff has a nice BS sticker on it although I don't know what BS their on about ;).
Last month fitted and clipped 380m split concentric
Tested found .25meg neutral to cpc
Cut in the middle found both half’s got faults
Cut again all faulty
Ripped it all out
Tested a 3m bit 3megs
Will not be buying Doncaster again in a hurry
gaz
Ripped it all out
gaz
doncaster-that's what i use from cef
i thought that was a good brand
i assume you complained -what was the response??
on all big sites not that ive been on one lately they get you to ir the cable while its still on the drum to make sure its ok before cable gang pull it in surely were not going to have to run 100m of t&e on drum to test first
Hi all, the ESC have been harping on about this for a while in their switched on magazine Atlos Kabel a huge Turkish Group have lost their BASC ticket over it ESC recokon they have confisacted and destroyed loads. We been cutting a metre of the statr off all Drums and Testing before installing. As the ESC reckon multiple brands and type affected. Check out the back issues avalible from their website. ;)
Reply to BBC1 now Fake Briton and CABLE!! in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
So I’ve heard…. Maybe they’re mythological as well?
The wire can't go under laminate. And on top of concrete you need insulation boards (just xpf boards can go as thin as 6mm over here). Otherwise...
