Be very careful out there,it might hurt | Page 2 | on ElectriciansForums
Discuss Be very careful out there,it might hurt in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Had to fix a trailing swa,with 2g socket on the end of it.
Maintenance sparky checked it,peculiar voltage,40v.
I checked it with my volt meter ,sure enough 40v.
Plug my plug tester in,dead.
Checked the zs & v on my test kit,dead.
Checked with mains continuity tester dead.
Cut it with hacksaw,bang.
Radial serving a number of sockets,no Rcd,16 amp mcb,1.5mm 3 core.
Thinking,the sheath of the live not contacting terminal on socket.
Never take anything for granted.
Recently I was scrabbling about in a loft looking for a JB feeding an outside light that was not working.
Isolated all the lighting circuits, stuck my hand in blind to pull out the JB.
Got a belt of an old ceiling rose used as a JB without the cover.
The moral of the story....
How hard is it to say 'I'm going to turn the power off while I have a look'
FWIW whatever earache I get on here I've already said to myself. :)
few years ago, my lad was with me on a job. 6.0mm redundant shower cable was to come out. "that cable is dead" says the wet pants. laddo cuts cable Bang Flash, sidecutters wrecked. moral of the story... never trust a plumber, they're raised from birth as congenital liars.
test between metal parts and earth
totally spot on. it would be negligant not to test between any metal parts withnig 2m.
e.g leaning on a metal water pipe/scaffolding/steel beam/washing machine casing, testing in a light switch. no cpc continuity for whatever reason. Measure live to earth, nothing, touch the pipe, 240v shock.
Any metal that's part of the electrical installation or extraneous can create a hazard. That's why bonding/earthing causes a danger and shouldn't be done except where necessary (class I equipment or extraneous conductive part that cannot be insulated) .
Abit unsure how you measured 40v then nothing. Alarm bells would be ringing at that point. I always test between line to earth, neutral to earth and then earth to neutral with an approved voltage indicator. I then run my voltage pen around it.
However even if proven dead, I still wouldn't work unless I confirmed which circuit it was and the circuit was locked off. Had a nasty belt once because I thought I had isolated the correct circuit, turned out it was fed from another mcb :-o
[ElectriciansForums.net] Be very careful out there,it might hurt
Reply to Be very careful out there,it might hurt in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
