becoming a domestic electrician !!confused!! | on ElectriciansForums
Discuss becoming a domestic electrician !!confused!! in the Domestic Electrician Forum area at ElectriciansForums.net
J
johnoconnor
hi I am looking if someone can guide me in the right direction i currently i qualified electrical engineer and work a 4 on 4 off pattern but i am wanting to see how to become a domestic electrician below are the current qualifications i already hold and i am going to do the 17th edition first amendment soon so any advice on what else I will need to acquire will be a great help cheers
current qualification:
BTEC national certificate level 3 (electrical/electronic engineering)
National Vocational Qualification level 3 (engineering maintenance (electrical))
semta modern aprenticeship in engineering
You are confused!!! you hold a higher job and want to step a lot of rungs down the ladder and enter an industry been throttled with too many domestic sparkies which are seeing prices and wages driven down .... entertain me and explain why you would wan to do such a backwards measure?
Become a plumber. Then you are more than qualified to do domestic installs. Or at least that's what your ego will tell you.
Seriously though stick with the job you are in unless you want to be undercut by some incompetent shrewhead who will do the job for nothing.
Reply to becoming a domestic electrician !!confused!! in the Domestic Electrician Forum area at ElectriciansForums.net
  • Solved
An NVQ is a vocational qualification and is based upon your work experience and what you put into your portfolio for your assessor to judge you...
I have not missed it on the website as I know the background to it Unfortunately from information posted on this forum a number of years ago I...
