So the built in wardrobes are being taken tight to the bedroom door architrave. Surely they could stop 2 inches shy to allow room for a wall mounted (architrave) switch.
Get the chippy to build a backing for it and just stock it in the side of the cabinet using a fastfix box.
Energy saving lambs save energy by lying about all day watching Jeremy Kyle on tv instead of gamboling around the meadow.
They are often to be found in Scouseland and parts thereabouts.
There have been reports of them being found in Sunderland too.
only ones you'll find in scouseland are already chops.
Thanks for the replies guys. The job is completed and these wardrobes are an after thought. The switch is a 3 gang switching a line of down lights and 2 pair of wall lights (3 pull cords a bit much). Trust me if I knew these wardrobes were going in this position the switch would've been somewhere else. I did give the option of trunking inside the wardrobe and putting the switch just inside the bedroom door on the face of the panelling but customer doesn't want these new wardrobes touched. Just never fitted a switch outside a bedroom and was unsure if there was a reg not allowing this. Outside the room it is. Thanks again for your replies.
I would go for a pull cord from the roof too, rather than using if outside, if it as a door and it's closed u are cut off from it and if kids are in the house you know they will turn it off when someone Is inside!! Never actually seen a bedroom switch on the outside, only a bathroom switch on the outside!
I don't think it would be practical to fit the pullcord on the roof, the cord would have to enter the room through the window, and when the window is closed it wouldn't operate at all.
Could you have a pull cord for, say, the downlighters, then the other switches elsewhere? Then you could switch the lights on when you enter the room like normal people do, and turn the other lights on as and when you want them.
I'd be tempted to ask the customer where they think the light switch should be. Maybe it should be downstairs next to the CU, then it's not in the way at all.
Bedroom Switch Position
Talk Electrician Forum
thomas-1981,
telectrix,
