Believe it or not this example has supposedly been tested and certified! | Page 3 | on ElectriciansForums
Discuss Believe it or not this example has supposedly been tested and certified! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
No busbar covers. No blank plates. Socket missed and now plastered behind wall unlocatable. No rcd/dual colour labels. No circuit designation (I have to find it when didnt do install) bonding forgotten and not connected. Light fittings not installed yet. Have to block for testing
Ive had to test circuits that havent been connected yet... I.e just a cable hanging out the wall waiting for data comms
I think the issue might be the installation method as it's not clear if these circuits are installed in the wall or if there are socket outlets that appear to have no rcd protection.maybe it's surface or in steel conduit
whats the problem here?
All you do is contact the premises owner show him the board has not been marked up, they will gladly provide the installers details, you contact the installer, they will provide you with the EIC/EICR and you mark up the board accordingly.
Reply to Believe it or not this example has supposedly been tested and certified! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
