F
fuel
Evening all,
Was wondering if anyone has had any good experiences with voltage testers more on the "basic" side, by means, im a first, coming second year apprentice now and im looking a new one without all the fancy clamp meters etc attatched as i dont really need it just yet, i just want a decent one that will prevent me getting lit at some stage.
Thanks,
Mike.
try test-meter ( forum sponsor ).
Always used Martindale,the one with four neons.Does voltage indication,nothing else.
wont pick up ghost either..
unlike some of the neon ones...
i have a few AVIs kickin about...
i have a di-log ..and i swear by it....
i`v got a metrel one as well...load of crap....
got a martindale...and another martindale one for phase rotation...both decent kit with nice meaty cables on them for the sprung prods...
A basic fluke is a good value bet. I have a fluke t50, good reliable bit of kit for voltage and continuity indication. I think the t90 has replaced this now. Should be about £30.
I like the t5-500 and 1000 etc.
I dont trust the t90 I had one die on me after less than 2 months light usage.
ive got a kewtech kt200 from screwfix for £50 now.
unless your company says you must use a voltage indicator.
much more convienient to have one with continuity on it as well as they are the two most common tests you will use
if it is a proper company make sure it has gs38 approved leads etc, you might get in trouble otherwise
Went for di-log as mentioned by glenn. Combi-volt 2, lcd,continuity etc. Complies with GS38 as said by shanky. T5-1000 Looks a good job, but bit pricy for me at the minute.
Thanks for the suggestions folks!
Best BASIC voltage tester?
Electrical Tools and Products
fuel,
mechelec,
