W
wallyanker
Hello.
Customer wants 6 bulkhead lights running down a garden wall about 15-20 meters long to illuminate the path. I plan to fit a switched fused spur from a socket in the dining room, through the wall into a weatherproof switch 1G 1W, then radial circuit for the lights.
Typical customer, wants it as cheap as possible and doesn't want to see the cables. Here's the questions:
1. What is the best cable to use for the job that can be clipped direct to the wall under the coping stones and then drop down to each light?
2. What is the switch rating of a weatherproof switch, will it be ok for 6 X 60w bulkhead lights?
Thanks in advance
Pete
Thanks in advance
Pete
