Best cable type for in floor heating | on ElectriciansForums
Discuss Best cable type for in floor heating in the DIY Electrical Advice area at ElectriciansForums.net
Avulstein
Canada
I am planning on redoing my basement floors and debating on adding underfloor radiant heat. It would be supplemental to my HVAC as the basement as being 70 year old house all registers are roof mount.
My question is due to the large area of main room roughly 13' Ă— 30' (4m Ă— 10m) 400 square feet or 40 square meters. This leads to my current problem, most single cables are less than 100m (300') or harder to find, (I've only found a single 1000' cable which is what I'd need to do the entire room). What seems to be an easier solution would be to run 10 parallel runs of heating cable. Using 33ohm/m cable that would roughly be 10 Ă— 110Watt circuits. Which of these would be the better option. The single cables systems seem to all run around 3000-4000 Watts.
Is there any disadvantage to running the parallel circuits rather than the single cable system?
TL;DR
The more common in floor heating systems are single cables per room. These run about 3600Watts, another option would be run 10 Ă— 16m runs in parallel with 33ohm/m heating cable. This should be 10 Ă— 110Watt or 1100Watts. Is there any disadvantage to running the parallel system?
Single cable electric underfloor heating systems are thinner and easier to repair (specialists work in this area, usually the tile industry as that is who would traditionally install it). Double are thicker and can go up to 200W/m2 and are the more common.
We would run the cables to a junction box and that to the thermostatic controller and that to a switched fused spur but often the load would require its own feed as they are power hungry heat source. Lovely to walk on.
Just wondering what prices compare as www.uheat.co.uk are forum sponsors and offer discounts to members.
Reply to Best cable type for in floor heating in the DIY Electrical Advice area at ElectriciansForums.net
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
