Best gland options | Page 2 | on ElectriciansForums
Discuss Best gland options in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
New induction motor turned up at work today.
The entry options are now 20mm and 45mm.
The previous motor was wired in 5 core, 6mm S/Y, through a 32mm compression gland.
I would prefer to make the S/Y off with a proper cxt gland.
A cxt32 is the size I will need. I am not sure what size the body of the gland will be and how it will make off into the 45mm threaded cut out.
Would a reducer be the best option to suit the gland?
M45 is not a standard size, I expect it is a pg thread
Pg36 is 47mm across outside of thread.
So a male pg36 to m32 thread converter may do the job
Drill the 20mm hole out to 25mm or 32mm and just fit a gland with a backnut. Ignore the 47mm hole, it's a red herring designed to make you waste days looking for adaptors.
Other option is if the 47mm hole has a threaded blanking plug then drill the blanking plug to accept you fave sized gland and refit it.
Reply to Best gland options in the UK Electrical Forum area at ElectriciansForums.net
I wouldn't rely on the ghost immobiliser on its own. My hire vans had them fitted, we lost a key and had a guy come out to cut and programme a new...
