Best IP65 adaptable box with Din rail for outside placement. | on ElectriciansForums
Discuss Best IP65 adaptable box with Din rail for outside placement. in the UK Electrical Forum area at ElectriciansForums.net
Andy C
Wirral
Hi All,
Quick question, I am going to provide a supply to the above from the far side of a house to intern supply 32A to a large hot tub and also a supply for some later outside lighting and maybe a patio heater. What reliable box would you suggest? It must have a din rail and 2 connection points/rails for neutral and earth bars. The connections to the box will be max 3 small armoured cables all bottom entry.
I am having difficulty finding one to suit my purpose and hope you more experienced types out there have fitted something similar.
Hi All,
Adaptable Boxes | City Electrical Factors - http://www.cef.co.uk/catalogue/categories/cable-accessories-adaptable-boxes
Fill yer boots fit your own Din rail to your hearts content
If you're using a DIN rail why not use DIN rail terminals for the N & E?
For Adaptable box with din rail connections read.
Adaptable box
Length of din rail.
Suitable Dinrail connectors.
3 circuits, what about Ocpd / Rcbo?
What about Garage unit as Andy78, mounted within a large Adaptable box if you don't want them easily accessable.
Just read you want small.
Looks like small adaptable box with Choc blocks in it then.
[ElectriciansForums.net] Best IP65 adaptable box with Din rail for outside placement.
Adaptable box
Length of din rail.
I could mount it quite high so you would need to stand on something to access it.
If I used an IP 65 garage unit then it would be easier but rule out any further expansion. I wanted the RCD outside and was going to take the supply from a non protected 32amp breaker in the main consumer unit to prevent RCDs in series and discrimination issues.
Reply to Best IP65 adaptable box with Din rail for outside placement. in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
