Best JB to bury - driveway lights | Page 2 | on ElectriciansForums
Discuss Best JB to bury - driveway lights in the UK Electrical Forum area at ElectriciansForums.net
Nottingham
Hi
I am looking to install some driveway up lights on my new drive way, either side of my drive is grass/gravel (soft dig)
I have spoke to a couple sparky mates and they have done it with galv conduit t boxes, wagos and magic gel (or similar) with gaskets/box lids. SWA between the boxes and flex out to driveway. Then bury these boxes to the side of the driveway so they aren’t on show, I know not ideal but no where else to put JB’s
My question is, is there a better way to do this? What’s the best thing to bury? Wiska box? Galv conduit box?
Any advice/ information greatly appreciated
Many Thanks
I am thinking of using these
However good your joints are (and there’s some good suggestions above), it won’t matter unless those lights have incredibly good drainage around them. They are almost certain to let water in sooner or later imo in the real world.
You want ip68, which usually means ELV. Look at Collingwood. Much more money, but I personally wouldn’t fit that Aurora fitting. Learnt my lesson the hard way years ago.
They’d probably be ok in raised decking, anything else, forget it.
Not sure what a junction hub is but are these suitable for burial and how is the voltage relevant.
  1. Safety – 12 volts is inherently safe for children and pets
  2. A bigger range of good quality, smaller fittings to choose from.
  3. Easier installation of cables in borders and planting – flexible cables to spike spotlights can be several times longer than to 240 volt garden lights and you can move them around more easily.
  4. A better range of lamps to choose from which are brighter, whiter, more efficient and longer lasting than their 240 volt cousins. Some 12 volt lamps are twice as efficient as their 240 volt equivalents.
  5. If you have an accident with a low voltage cable it is usually easier to fix.
  6. Low voltage transformers and power supplies absorb transients such as those caused when a lamp blows and are, to a degree, tolerant of earth currents arising from a bit of damp in light fittings. A little bit of dampness might not affect a 12 volt circuit but it could render a 240 volt circuit unusable.
You can use flexible cables, HI-Tuffs of similar length for their installation rather than armoured, and you don’t need to bury the cables approximately 600mm, as you do with LV installations.
1. Regulations do not consider children or pets?
2. 12v have a larger range?
3. Why is installation easier, quote a Regulation.
5. 12v is not low voltage but 230v is??
Reply to Best JB to bury - driveway lights in the UK Electrical Forum area at ElectriciansForums.net
