Best place to get a copy of BS 5839 part 1 2017 please? | on ElectriciansForums
Discuss Best place to get a copy of BS 5839 part 1 2017 please? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Try EN5839 Part 1. I have often found the same standards, free download in English by substituting the EN instead of BS.
It is not possible to obtain BS5839:1, PDF or hard copy for less than £300 unless you are a BS member which is only beneficial if you purchase lots of Standards. I have seen these versions for £99 and if something is too good to be true it invariably is.
Reply to Best place to get a copy of BS 5839 part 1 2017 please? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
BS 5266-1 Doing a lot of three hour drain. And when the lights fail or so bad they don't show much light (hight ceiling and it's a small LED...
