Best safety shoes for electrician ???
Are there safety shoes (steel toecap) specially for electricians ?
i.e in the U.S there is an EH (electrical hazard) boot.
I ask because a while back I was wearing "standard" safety boots, in a perfectly dry panel room when my finger accidentally touched a live terminal, and I was surprised to get a quite painful shock.
Any recommendations:
Shoes preferable to boots.
Steel toecap essential
these are not proper electrical boots, :)
Thanks but I am not looking for "proper" electrical boots. I have worked in the past in power stations at up to 220 kv and have all the gear including boots, tools etc.
I am now working in a commercial environment where max to earth voltage is 240V and was wondering if there was a "make" of standard safety shoe which would have a "better" type of insulated sole than others.
i.e I don't intend touching exposed conductors, but if there was a pair of safety shoes which would be better in case of an accidental brush with a conductor, then it would be better to have them, than say a pair of "hob nailed" boots.
Any shoes will work for low voltage.
Do a 1000v insulation test on your shoes. Mine are £15 steel capped, steel sole and leather; possibly the worst combination. Still passed an insulation test.
I have a pair of Trojan boots from ARCO which arecomposite material rather than steel and are non conductive got them for when Iwas working in LU & edf sub stations, had them over a year and still ingreat condition and really comfortable
The most important parameter, when choosing electrician’s safety footwear, is the dielectric strength of the sole. Ensure the footwear is rated to one or more of the following standards:- BS EN50321:2000, BS EN 20345:2004 Amt:2007, ASTM F1117-93 or CZA Z195-02 these may variously certify sufficient dielectric strength for working up to 1000Vac or 1500Vdc, see details below.
1) Testing to BS EN 50321:2000 - This European Standard covers electrically insulating footwear for the protection of personnel working on or near electrical installations. Boots are tested to ensure that they can withstand 10,000V without puncturing and also to check that current flow does not exceed 5mA when a 5000V potential is applied. They are certified for use up to 1000V AC and 1500V DC (class 0). The red double triangle symbol identifies the boots. The class (0), batch number and date of manufacture are also stated.
2) Testing to BS EN 20345:2004 Amt:2007 – This European Standard covers various parameters of safety footwear, part of which includes the dielectric strength of the sole for the protection of personnel working on or near electrical installations. The sole must have a dielectric strength >1000MΩ at 18kV for 1minute in dry conditions and the leakage current must not exceed 0.25mA there after.
3) Testing to ASTM F1117-93 – This American Standard covers electrically insulating footwear for the protection of personnel working on or near electrical installations. The sole leakage current must not exceed 0.8mA at 15kV 60Hz and 2.47mA at 30kV 60Hz.
4) Testing to CZA Z195-02 – This Canadian Standard covers various parameters of safety footwear, part of which includes the dielectric strength of the sole for the protection of personnel working on or near electrical installations. The sole must have a dielectric strength that, at the point of manufacturing, has electrical insulating properties intended to withstand 18kV, 60Hz with zero leakage current to ground for 1minute in dry conditions and not exceeding 1mA there after. A white rectangle with orange Greek letter omega indicates soles that provide this level of resistance to electric shock.
Note:- It is most important where compliance to muti-part Standards [ 2) and 4) ] are quoted in the footwear specification that you check that this specifically applies to the sole dielectric strength, as this may not be guaranteed.
Cofra New Electrical Safety Boots with Composite Toe Caps & APT Midsole
Buy Workmaster Dielectric® Yellow Safety Knee Boot from Arco Limited
We are not talking about contact with 10,000V+
This is like getting eye protection rated bulletproof for using an grinder.
Who cares what my shoes do at 10,000v if you are only dealing with 400?
I use the NikeID website for my work footwear. For £120 you can custom design yer own trainers, choose all the colours, logos etc. Very comfy and you'll look the business on site.
I'm guessing they aren't steel toe cap. It's difficult to know if your joking or not.....
And to the person saying about who cares about 11kv......
How do you know the op only works in 400v? And I've not read the whole thread so excuse me if I'm wrong
No they are not and no I'm not joking, although I tend to wear them on the town for six months or so before they are demoted to work trainers. Never understood why people wear steel boots in houses, bloody uncomfortable and housewives tend not to appreciate them on the carpet.
I wear mine when at work at all times because I've had the pleasure of an idiot apprentice dropping a full roll of 4mm T&E on my foot while I was wearing trainers
I don’t care what boots you’re wearing they aint going to save you from11KV!
The Spice Girls got near to it though.
Being serious, I’ve always had to wear foundry boots steel toe cap and a steel plate in the sole. Not comfy but they’ve saved my feet several time.
Zimmer,
Zimmer,
