best screwdriver cordless | on ElectriciansForums
Discuss best screwdriver cordless in the Electrical Tools and Products area at ElectriciansForums.net
000aces000
Hi could do with a bit of advice
Im looking to get a cordless screwdriver either a 3.6v or 10.8v
Just wondered what you think is the best value for money and performance
yep I have Power Led torch which blinds people miles away, and battery also fits the impact driver version and most handy the Multimaster type multi tool for cutting in boxes and pretty much anything. like a multispeed battery op version of the "Fein Multimaster" which are extremely useful.
Check out new deals on the Bosch L-Boxx I think it's called... as you would pay £120 odd or less for the driver you get here in Jersey the driver, impact driver, torch and multi cut tool for £199 or £200 in a hard case V.A.T. free as always !
Hope this helps bud.
Go for the Bosch 10.8 mate! I got it and I LOVE IT! Easy, got a nice holster, powerful (within reason) and the battery lasts for quite a while (sometimes I use one battery for weeks before it gets flat)! The other one that is almost as good is the Makita set. If you need an impact driver as well (I doubt it if you are a sparky) than the Makita twin pack is better value for money. If you need a driver only than Bosch!
10.8 Bosch all the way it's like a third arm if it broke now I would buy one exactly the same again
those 3.6v look a bit like DIY specials
got myself a 10.8 bosch, the old model , on ebay for 60 quid with two batteries.
they last whole day on the site no problem.
for some reason the old model feels better in hand that the new fancy one.
its got no problems screwing 4mm screws into wall plugs or wood and that is what i`m normally using it for.
bigger screws for floor boards etc do with my combi drill.
forget 3.6v, toys for repairing childrens toys or assembling a pc
Reply to best screwdriver cordless in the Electrical Tools and Products area at ElectriciansForums.net
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a...
You can buy the wera ends in singles for replacing broken and worn ends which is nice
