best tool to chop 150mm 4core swa | on ElectriciansForums
Discuss best tool to chop 150mm 4core swa in the UK Electrical Forum area at ElectriciansForums.net
B
bigdavs83
Have some 150mm 4 core which is to be stripped from its tray and (ahem) disposed of. However it's a heavy blighter so want to chop it into metre long lengths. What's the best tool to be achieving this?
either a 9" grinder or chop saw, I have used both in the past to do the very same.
If it's on the floor then a chop saw makes light work of getting it into managable lengths. If it's up in the air then clearly something hand held is needed. I would be tempted to use a recip saw like Dillb suggested. Either that or a pack of fresh 18tpi hacksaw blades and your best w*nking arm
Reply to best tool to chop 150mm 4core swa in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
