B
bigdavs83
Have some 150mm 4 core which is to be stripped from its tray and (ahem) disposed of. However it's a heavy blighter so want to chop it into metre long lengths. What's the best tool to be achieving this?
Discuss best tool to chop 150mm 4core swa in the UK Electrical Forum area at ElectriciansForums.net
If it's on the floor then a chop saw makes light work of getting it into managable lengths. If it's up in the air then clearly something hand held is needed. I would be tempted to use a recip saw like Dillb suggested. Either that or a pack of fresh 18tpi hacksaw blades and your best w*nking arm
if you use tct blades etc then very little.Problem with using a grinder or similar is the amount of smoke and fumes it kicks out...
I'd recommend a battery bandsaw, buy the bare body that matches your drill set so you can use your batteries, bosch, hilti or what ever...
I'd post a link but my phones playing up...
Reply to best tool to chop 150mm 4core swa in the UK Electrical Forum area at ElectriciansForums.net
