All of the above is good advice and I too advocate buying good quality stuff that will last. However, you don't need to start expensive and hopefully you'll get the opportunity to try out different tools as you gain experience and build on that. I actually use
1) Very cheap (my preference) small (150-160mm) & larger cable cutters.
2) LED Lenser AAA battery head torch
(not the brightest model, but the batteries last longer) invaluable.
3) Quality VDE Screwdrivers (Bahco etc...mid-range are fine).
4)12v, 18v, 240v Bosch blue...others are also good but I have experience of dropping these on occasions and leaving out in the rain (not 240v)...they take it everytime.
5) "Large" folding plastic step 390-400mm (H) from hobbycraft (small footprint for domestic ceiling work) + 5 tread fibreglass steps
6) Quality drill bits if used everyday (forget cheap large sets).
7) 10mm2 G/Y single cable 200mm long. 90 deg bend To check for obstructions for D/Light positioning or location of joists/pipes.
8) Knee pads
9) Duck tape.
10) vaseline
...I think i need to stop now....need fud
Screwfix Titan brand LED distance measure is a god-send for plotting down lights. A chalk line is cheaper than laser and almost as good for the task. Rolling tool boxes are handy depending if you're in a car or on the tube; with a small soft bag of the basic (second fix) tools. What else? Spirit pens and pencils, OH and a volt stick. A non contact voltage detector - OR use your tongue. A combi-drill and impact driver pair is useful but costly when you start.
I knew that would raise an eyebrow. There is very little chance of changing some ones choice of tool without practical demonstration but I know of two sparks that went from **** taking to wanting some in a morning.
https://www.amazon.co.uk/dp/B00TPP2...=9046601&hvtargid=pla-451189240484&th=1&psc=1
ive got a "7 in 1" set of snips, cant see myself using scissors for stripping cable
and £32 for scissors :eek:
Draper Expert Ergo Plus 7 in 1 VDE Pliers 185mm - https://www.toolstation.com/shop/p50196?r=googleshopping&rr=marin&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=EAIaIQobChMI4s6zwpep2wIVDt0bCh099gPCEAQYASABEgJGifD_BwE
As an Amazon Associate we earn from qualifying purchases.
Never had the need for electrical scissors and never known any other electricians to use them out of interest what do you use them for?
it's the sidecutter bit that's too short to cut 2.5mm.
hmm, i havent had that problem, just sometimes it gets stuck in the crimping part and doesnt cut
electrical scissors...........
A few of the lads use them for ships braided cable and to be honest they do a neat job. I prefer small lindstroms or bah cos but it really is horses for courses
i like the 7 in 1 tool i have mainly for the 5mm or so of "flush cut" snips, no more jabby tiewraps
I'd recommend multimaterial pipeslice is you're going to be working with pvc/steel conduit. I use the Rothenberg No. 35 myself and love it, especially as I can't cut conduit straight for toffee ?
Curious to know, how long do the blades last on that when used on steel conduit?
Been using mine since September with no issues yet, according to the manufacturer it shouldn't be any issue with conduit, as for how long the blades will last; I'll let you know when mine get changed ?
Yea that thread is old but the subject is a common one - Do we have adticky in the tools and products section with this type of content on, if not might not be a bad idea to have one, users then can add little gems they find useful (and of course talk about basic kit and brands etc)
look at post #56. I would not be without this for flex and coax. can be got from cpc at about half that price.
The bag of hand tools you build up will be more valuable and less easily replaced than the headline pieces such as battery drills. This is one, simple lightweight piece I would not second fix without C.K Re-threading Tool M3.5 x 0.6mm - https://www.screwfix.com/p/c-k-re-threading-tool-m3-5-x-0-6mm/59312?kpid=59312&ds_kid=92700048793290430&ds_rl=1244066&gclid=CjwKCAiA3uDwBRBFEiwA1VsajCJkIYWo4YmbQf7-nr_O4BwhAi-MfqbPI_QmE51m7eWyPCBdQocQrxoC5xkQAvD_BwE&gclsrc=aw.ds
3.5mm Hand tap to rethread cross threadded back boxes.
Cambridgeshire
Best Tools For a Startup Electrician
Electrical Tools and Products
Zack McCoo,
Marti,
