Best trunking to use up to a CU? | on ElectriciansForums
Discuss Best trunking to use up to a CU? in the UK Electrical Forum area at ElectriciansForums.net
North East
Hi, would anyone be able to recommend what kind of trunking i should use from a consumer unit down to floor level as the cables come from under the floor up along the surface of the wall into the back of the consumer, i am currently working on a board change in a domestic where all the cables were just clipped to the wall, but im trying to protect them as well as make a neat job so if anyone could point me towards best form of trunking would be appreciated.
Depends on number of cables.
Domestic, I would use pvc rather than metal.
Square looks to blocky, if you need 75x75 or 100x100 size.
Jobs I’ve worked on where there is existing trunking it has either been 100x50 or dado trunking run vertically.
Both have been from CU up to ceiling rather than down to floor.
You would have to look at the charts on trunking and conduit to work out the size of the trunking first. As a rule of thumb around 45% free space is good in the trunking. Look at the factors in the regs to work it out. Having done that if you are going straight into/onto the side of the CU then it is pretty easy if doing a 90 degree turn then you will have to drill the side of the trunking to accommodate accordingly.
Absolutely, if the home owner is wanting to hide the trunking, they can box it in!
Reply to Best trunking to use up to a CU? in the UK Electrical Forum area at ElectriciansForums.net
https://www.d-line-it.com/u-clips/
2 3
The suggestion from @UNG to use Unistrut inverted is good, as it is 41 x 41 outside or 41 x 21 (I think, from memory) and you can get it without...
