hey guys
we have done an EICR on a 2 bedroom bungalow, the supply is a 25mm 4 core 3 phase SWA to the property, it is supplied from 80amp fuse.
although it is speculative as the cable is underground we reckon the distance is around 600m :fearscream:.
it has being installed around 10 years and no evidence of thermal damage or any concerns of equipment not functioning correctly as per tenants.
the Zdb is 1.89 so disconnection time is not achieved either. the volt drop is around 72volts based on potential load of 80amps.
there are no 3 phase circuits in the installation but it is fully electric so it does have 6 panel heater and an electric hob/oven.
what code would you give based on the voltage drop allowance not being achieved.
hey guys
C2 but for not meeting disconnection times or max ZS.
Even the supply cable a BS88-3 80 amps has a max ZS of 0.4 ohms 80% value
The cable is way undersized.
If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not considered for an EICR.
Nottingham
exceeding voltage drop
Sb8389,
westward10,
