Best Value/Brand tools for when just starting out | Page 2 | on ElectriciansForums
Discuss Best Value/Brand tools for when just starting out in the Electrical Tools and Products area at ElectriciansForums.net
Knipex plies, cutters etc . Wiha or irizola screwdrivers , fluke volt/ conti tester . Personally I've never rated CK just don't seem same quality as knipex
You will of course need a proving unit for safe isolation purposes, I recommend Martindale voltage indicator and proving unit, or John Drumond VI and PU
For the tools that you use the most buy the best you can afford but you also need to handle them to see if you can work with them, as an apprentice I bought a pair of Elliot Lucas pliers which I still have after 35 years don't use them much as the insulation has worn but they where handy as after cutting through a live cable in a ceiling void the burnt out hole was handy for stripping cables.
If you are self employed which I believe you won't be then any expense related to work is deductible from your tax bill.
I made the mistake of buying cheap as an apprentice and ended up replacing literally all of it as time went by.
I now usually just buy CK for hand tools and they seem to last well. Can you not speak to your wholesaler? Mine always hook me up great deals on CK stuff.
Reply to Best Value/Brand tools for when just starting out in the Electrical Tools and Products area at ElectriciansForums.net
What attracts me is, i enjoy working in trade i like keeping busy an grafting an getting to be proud when a job is finished, with the electrician...
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
