Best water pump pliers | on ElectriciansForums
Discuss Best water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
Are you actually using them for pump valves?
If so save yourself the grief and get a pair of these.
Now, not the most cost effective but as I got sent two by mistake from Amazon all's good.
I also have the pump pliers but have never used them on pumps, as I have the above.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Bahco non=slip. i have 2 of them brilliant.
[ElectriciansForums.net] Best water pump pliers
no contest. bahco all the way.you know where the name knipex came from..... coz they knip your hands, and ex is blood exiting your body.
Another vote for Bahco, I've got quite a few of their tools and they're very well made.
With the Bahco ones, you don't need to press the button to make the jaws closer, only wider. This makes them quicker to use. You just slide the handles closer and it ratchets closer.
On my Knipex Pliers Wrench (the smooth jaw ones), the adjustment is too fine, I find them fiddly to use. Not sure if that is the same for the waterpump pliers or not.
Cheers and yeah will be using for armoured glands and tightening couplers bushes etc. Im torn between bahco and knipex
Then these
They do smaller, I also have these and the smaller ones for locknuts, glands etc...
Reply to Best water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
Some year back there was a case of a young girl killed by being sucked down to the bottom of a pool when being emptied through the power drain...
M
Rubi DC-250 1200 Water Pump Replacement Hi, I'm really hoping someone can maybe help. I have a Rubi DC-250 1200 and it looks like the water pump...
mattwaddy
M
