Best way of fixing boxes to crumbly walls..... | on ElectriciansForums
Discuss Best way of fixing boxes to crumbly walls..... in the UK Electrical Forum area at ElectriciansForums.net
LewisM
Luton
Hi I'm doing a rewire of an old victorian terraced house built in the 1890s the plaster and bricks are extremely fragile even with a hammer and scutch chisel the brick just crumbles away leaving no solid fixing, what is the best way of fixing boxes back square? I've thought about expanding foam but will that not expand and push the boxes back out?
It's hard to see from the picture but the brick is all jageded and in pieces.
[ElectriciansForums.net] Best way of fixing boxes to crumbly walls.....
A technique I've used in the past is to take a 12" - 18" length of batten, drill a couple of 4mm holes in it at the same spacing as the holes in a fitting, then use 3.5mm screws to attach the batten to the front of the box.
Offer this up to the wall, and nail, wedge, prop or any way else you can think of the batten flat against the wall. Mix up some mortar and pack around the box.
As all the above ^^^^
In the past I have used a couple blobs of grip fix to stick all the boxes in position then filled round them after with either bonding or drywall adhesive. This way you can get all the cables in then do the back filling all in one go.
Be sure to prime the brick first ideally with a very watered down pva mix.
What about surface mounting all boxes and sleeve it up the wall or across the wall using PVC conduit
Reply to Best way of fixing boxes to crumbly walls..... in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
