W
whazza22
Just after everyone's opinion on the best way to chase cable drops and box's without destroying the wall too much :)
Seen my mate use an SDS hammer and the wall looked a right mess!
The stitch method looks pretty good, does anyone know where to get one of those drill guides?
option 1 wall chaser use mask entire house covered in dust
option 2 SDS drill go all over the place but quicker
option 3 use a scutch slower but cleaner and controlled.
I use option 3 and only revert to option 2 will stone build properties.
Hope that helps
Chris
it was few years ago, but it was a bosch hoover and a bosch chaser! all i remeber is that we had to keep changimg the diamond blades co the walls were made of brick that contained iron filings or something like that
I use a chasing tool with a good vac, very low levels of dust, still dust sheet the entire room. I use a 5in grinder with a dust extract hood, again very little dust ,the sds causes more when clearing the chase and box. With the boxes I go past the edges of the marked out box this is so you get the full 25mm cut all the way to the very corners of the back box hole.
Best way to chase?
Australia
whazza22,
Voltimax,
