Hi folks,
Will be fitting first AMD3 board later this week. Using the Wiska spring tails kit on it. What is best way to drill a 40mm hole through the casing? I have cone drill bits up to 30mm and also have Bosch power change holesaws.
I found the cone drills much better in the past when drilling through Wylex switchfuse casings. I struggled with the holesaws in the past; found the teeth wear away quickly and it is harder to stop the holesaw wandering about a bit and knacking the case.
Opinions please!
Thanks, Neil
Opinions please!
Thanks, Neil
