Best way to install a very tiny light | on ElectriciansForums
Discuss Best way to install a very tiny light in the UK Electrical Forum area at ElectriciansForums.net
london
Hello,
Behind a tiny door in our under stairs cupboard we’d like to build a miniature room in which a little light would come on when the door is opened.
The door is about 12cm high
No power so needs to be battery operated.
I thought about those PIR USB LED lights for cupboards which would work but the light would ideally be hidden, lighting from above. I’m guessing the PIR can’t see me if I can’t see IT. Or do they also react to changes in light and dark?
Anyway, any ingenious suggestions gratefully accepted.
  • [ElectriciansForums.net] Best way to install a very tiny light
To do the room justice I think you need to make a minature light switch using a teeny weeny lever switch wired in 5mm surface mounted conduit to small warm white LED on the ceiling. Obviously your going to need to make a tiny consumer unit containing a single sub-minature circuit breaker and a couple of lithium hearing aid batterys to supply it. Should keep you busy for a while.... :)
Now then Tel, you've been quiet again. Hope all is well.
not been on for a while since having a partial hip replaced ( the ball on top of the femur because sawbones could not fix the break close to the joint ). need some muscle exercises to get the legs working better.
ouch.
get well soon.
Reply to Best way to install a very tiny light in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
J
SVP (grey water) gases leaking out - What do you see (pics)? Hi all, I would really appreciate your eyes on these pictures - What do you see ...
Jayp07
J
