best way to joinn cables in cu change ? | Page 2 | on ElectriciansForums
Discuss best way to joinn cables in cu change ? in the Talk Electrician area at ElectriciansForums.net
I was brought up to believe that crimping of solid cores is "bad practice".Surely an adaptable box with fixed base connectors of the correcting rating for the circuits involved should do the job fine. Obviously the correctly labelling should be fitted to the box cover which should be mounted in an accessable position.
I have been told in the past, that over time the copper will fuse together with the crimp/lug.
response to uksel, won't the solder eventually melt a tad with electricity causing heat? I heard in one situation that sum1 soildered sum machinary, aparatenly a big mistake because the soilder melted and caused it to burn out or sumit?....
Hi LukeScotty
I think it's reasonable to say that this would only happen in the most extreme of circumstances, ie. house fire.
the connection is initially soldered on to the supply cables armouring anyway, the amount of heat it would take for the solder to melt is fairly substantial and the connection would be open and only really subject to room temperature. the heat of the supply cable would be very minor as the cable is generally sized for it's use.
at what point does solder melt. I have had the severe misfortune of working for my Brorther in law, plumber and I'll tell you when solder melts , it's FLICKING hot. not overcurrent hot , Flame hot! I can't see over current melting solder.,
What would be the best way of joining 6mm?
Whopping great yellow crimps and forearms the size of Ulster!!
agree that ideal word no crimping solid cores and adaptable box with din mount screw terminals inside
but its not ideal im afraid lol
Guilty of using crimps and still do when space is of a premium.
But, as suggested, suitable enclosure with din rail terminals is the way to go.
I have always stood fast on never crimping solid cables until very recently when i was in a position where it was unavoidable.
I remember thinking at the time about this forum and the various thoughts and I felt guilty doing it after making such a stance on here but I remember thinking to myself
'if you cant beat em join em (literally lol)'
I wont make a habit of it thats for certain but I suppose in certain circumstances I can now see why its unavoidable:)
I've used some of those HelaCon Plus connectors recently and think they're really good, cost £8.99 for 100 of the 3-way ones . As far as I'm aware they can only be used on cables between 1mm and 2.5mm, but i've seen some similar-ish ones on Ebay made by "Wago" described as "lever connector block electric crimps" which will apparently take up to a 4mm stranded core.
Reply to best way to joinn cables in cu change ? in the Talk Electrician area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
Crimp or Wago inline connector, my preference would be Wago push fit...
