I have a nylon one with brass ends.
From a support point of view?
Struggling to understand why it's frowned upon?
Probably have the same problem getting a draw tape through before you install the conduit, rigid would have been best, ease of install, more professional job, the list goes on.Pull a draw tape in and pull a piece of wire through before you install it.
Would have the same difficulty as doing it after the tube was installed.Pull a draw tape in and pull a piece of wire through before you install it.
Don't think anyone is saying it's an un proper job Gaz, just that 5 meters is a rather long run for flexi conduit, can understand why you wanted to make use of the flexi you had left over from another job, just not in this occasion imo, it it' twin and earth why use tube anyway?Does flex make it an "unproper" job?
It's ran through quite a few studs and fixed in numerous positions.
The cable has enough mechanical protection and the conduit had enough support. Is there something I'm missing?
Why the disagree? seems quite a simple conclsion doing it befre the tube is installed would be just as difficult as doing it after the tube is installed!!!!!!!!!!!!!!!! Still no surprise really.Would have the same difficulty as doing it after the tube was installed.
Oooooh, Matron.I have a nylon one with brass ends.
Beat me to it by a couple of minutes.Oooooh, Matron.
