Biomass ETA pc 20-32kw
Hi fellas,
Anyone any experience of wiring the biomass boiler in the following link? ETA Heiztechnik GmbH - ETA PC 20, 25 and 32 kW
I've wired loads of standard S Plan, Y plan, multi zone anf UFH systems but never a biomass.
The existing gas boiler system has two heating two port zone valves and a dhw zone valve.
I've taken a three channel programmer and all the gear expecting to wire up a S plan plus however the plumber says the programmer is not needed as all the controls are integrated into the biomass boiler.
Any help would be appreciated as I cant make any sense of the intructions.
Thank you
