Bit flummoxed as to what exactly to report/say on this? | on ElectriciansForums
Discuss Bit flummoxed as to what exactly to report/say on this? in the UK Electrical Forum area at ElectriciansForums.net
T
The Ghost
This is fed in 2 core 4/6mm (not positive) SWA. No earth except a bit of 2.5mm (blue sheathed with earth) on pirhana nut to earth bus bar. An atrocious install technique all round. The landlord did it. Swearing heartily at the spark who did not finish the job. Wrong MCB for the 2.5 on two of them. All radials serving a kitchen (commercial) Was called to inspect (not EICR) to give an opinion on the state of the installation. No certificates by the Landlord or Electrician who put the supply in (of course) This type of wiring evident throughout by the way not just the kitchen I was looking in. I mean a Landlord who cannot and should not install electrics commisioning ccts with no tests. How may laws is he breaking. Where do I begin with the clients? I am speechless at the moment. Ideas? I just can't decide wtf to say to them. Did Zs and RCD tests all met regs, tested all the points. You can see 32a mcb on 2.5 and 6a on 2.5 supplying four double sockets feeding 2 x 2kw induction hobs, bain marie and so on. I'll stop there for now.
[ElectriciansForums.net] Bit flummoxed as to what exactly to report/say on this?
Who is the client I assume not the landlord. The only way you can deal with this is provide an EICR stating facts and do not get involved with should they or should they have not done this and quoting laws
Vort should have put your sheriff badge on. before you started working on that .
Nay it is the tenants, who just moved in to this kitchen. They have not asked for an EICR just a look over and advise them as to how to proceed. For that matter it could be an EICR is appropriate, and maybe I should suggest that. However they want the Landlord to pay. When I got there he was frothing at the mouth about the electrician who did not finish the job so he had to do it. He said he was going to see him right away and will probably be in prison this afternoon. Seemed quite angry, so I thought better soft pedal observations at the moment.
The O.P has been asked to give an opinion, not and EICR.
My opinion would be;
It's not good enough to be rated Substandard.
It's not worth wasting any time and money investigating it further.
The only thing that can be saved is the C.U.
It should be isolated immediately pending a complete new installation.
If there was an incident in the premises involving anything in the pictures and the person who did that work had to stand up in Court and defend their actions, they'd better pack a suitcase, cause they won't be coming home anytime soon.
You could undertake a visual inspection stating facts then leave them to it and don't become the man in the middle. Don't make a mountain out of a mole hill and don't confuse poor workmanship with dangerous workmanship although there is evidence of both.
Reply to Bit flummoxed as to what exactly to report/say on this? in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
