Probably all in a days work for a professional electrician but it had me scratching my head. I wanted to fit lighting into a room but there is an en suite on the floor above, as you can see I made a hole in the ceiling and worked from underneath.
Discuss Bit of a challenge for me in the UK Electrical Forum area at ElectriciansForums.net
I prefer to use a J.B be it an MF one as a last resort don't like any joints you can't get to.If that JB in the void is going to be used to connect the cables it needs to remain accessible, if it wont be you need a MF connection box
ThanksQVS Direct sell an Excel 3 pole fused fan isolator switch which will fit a 1 gang box:
www.qvsdirect.com/excel-3-pole-fused-fan-isolator-switch-white?gclid=EAIaIQobChMI0tiq_NT21wIVEo0bCh3EMgfjEAQYASABEgJzQvD_BwE#fo_c=2242&fo_k=5474c0ee62e8fd294c07ea0e3251b96c&fo_s=gplauk
The switch live is just a trigger for the timer the fuse will be in the live to the fan motor.How does that help you fuse the PL and SL?
Use 1mm² twin and earth / three core and earth for ease.
Layout is variable but could be like this, if it is a timed fan.
Remember the work needs testing for compliance with the wiring regulations.
Once you turn off the bathroom light there should be no live on the SW live.Is it? Have you got a copy of the circuit diagram for the internal electronics of the specific fan being fitted here?
Reply to Bit of a challenge for me in the UK Electrical Forum area at ElectriciansForums.net
