Bit of advice would be much appreciated. | Page 2 | on ElectriciansForums
Discuss Bit of advice would be much appreciated. in the Australia area at ElectriciansForums.net
Goody
London
Hi,
Sockets are daisy-chained from the only double socket in the kitchen and stuck under cupboards as shown in the picture. Can't chase the walls and ruin the tiles. In this situation, how do I add more double sockets along the worktop, taking the existing ones down? Don't want to use surface mounted boxes.
Any advice is much appreciated.
[ElectriciansForums.net] Bit of advice would be much appreciated.
eng54 idea is a very good one,baring that the only solution might be to fit a fcu(not really great as only 13a or reinstate ring,although you said its poorly wired to begin with so might be costly,but if he wants a job done correctly and how it should be working then im afraid thats what it will need to be,a multitool(bosch or fein might be able to cut around the grout and prize the tiles off intact so boxes can be recessed,but thats going to take a while.i think e54s idea is best
Reply to Bit of advice would be much appreciated. in the Australia area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Thanks for the replies, I appreciate it.
