bit of help please and advise | on ElectriciansForums
Guest viewing is limited
Discuss bit of help please and advise in the UK Electrical Forum area at ElectriciansForums.net
daveyballs
can i use this free 6mm cable now to wire direct to fused spur 6mm cable
then run of fused spur 2.5mm cable to 2 double sockets .. from one to the other
so it be 32amp consumer 6mm cable to fused spur ,, then 2.5mm cable from fused spur to double socket ,, then spur to another double socket
any advice think it be a radial circuit
cheers
thanks for letting me join
why? terminating 6mm into a twin socket in a twin pattress where there is twice the space is a lot easier than into a FCU in a single pattress.
And to be perfectly honest I don't think any regulation or best practice allows for what is easiest for an amateur to do to be considered!
He states he is fitting two. You can't terminate 2 x 6mm in 13A socket outlet without a serious haircut (OP do NOT do this). Other wise he will have split 6mm.
Reply to bit of help please and advise in the UK Electrical Forum area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
Ouch. Danger notice to customer in my book.
