Bit rusty on regs. | on ElectriciansForums
Discuss Bit rusty on regs. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
Gavin Bear
I've not been active as a sparky for a little while, so bit rusty on regs. Esp. the new ones :)
Can anyone tell me if I should be worried about the sparky doing my kitchen?
[ElectriciansForums.net] Bit rusty on regs.[ElectriciansForums.net] Bit rusty on regs.
This is the finished wiring.
were the pipes in place before the cabling? did the plumber alter existing pipes after the wiring was installed?
them pipes ain't been altered since you left school. mike. oops. they would have been lead then. :ban:
View attachment 30844View attachment 30845
i'd be worried. first about those cables and second about why your missis ain't polished the copper pipes. :baby:
Yep all in place before cables were hung over and pulled tight against pipes.
The real worry is that the sparky is supposed to be NIC etc. :uhoh2:
The next problem is that the kitchen fitter is due 8am monday and will cover this all up.
Should I stop him?
Get him back and get him to do the job right.
To the OP, I've attached a picture of wiring I put in recently for a new kitchen, not saying I'm better than anybody else but I'd say it should look something like this - and whenever it's unavoidable running cabling close to [especially hot] pipework I'd always place a barrier between, something as simple as a small piece of plasterboard would do.[ElectriciansForums.net] Bit rusty on regs.[ElectriciansForums.net] Bit rusty on regs.
To the OP, I've attached a picture of wiring I put in recently for a new kitchen, not saying I'm better than anybody else but I'd say it should look something like this - and whenever it's unavoidable running cabling close to [especially hot] pipework I'd always place a barrier between, something as simple as a small piece of plasterboard would do.View attachment 30849View attachment 30850
TBH, i'd have cabled direct from box to box horizontally, saves the surface cables below worktop. kiychen fitter will need to notch his vertical weetabix boards.
The pipe that the cable is tight against is the heating feed from the boiler, so as hot as they get.
The big question is does it meet the regs? Or do I have cause for complaint.
Thanks for your help people.
Reply to Bit rusty on regs. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This situation is not uncommon and is absolutely nothing to lose sleep over. There are plenty of properties sold without the 'required' electrical...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
  • [DIAL] What Is The Cancellation Policy For Expedia?
    π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ π•‘π• π•π•šπ•”π•ͺ. π•‹π•™π•šπ•€ π•žπ•–π•’π•Ÿπ•€ π•ͺ𝕠𝕦 π•”π•’π•Ÿ π•”π•’π•Ÿπ•”π•–π• π•žπ• π•€π•₯...
  • Song words.
    All I Wanna Do Is Make Love To You View: https://www.youtube.com/watch?v=OAfxs0IDeMs
  • What is the refundable option on 𝔼xpedia? Cancellation Policy
    What is the cancellation policy for 𝔼xpedia? π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ...
