Bizarre dead short between Neutral and Earth | Page 2 | on ElectriciansForums
Discuss Bizarre dead short between Neutral and Earth in the UK Electrical Forum area at ElectriciansForums.net
1shortcircuit
Firstly, please let me explain the fault on the circuit HAS been rectified. This was achieved by splitting the offending circuit (kitchen ring) into two radials and putting each leg on their own 16A mcb on the same RCD.
Attended a property to do some remedial works on the kitchen ring, New dual RCD protected board already installed and just there to put rubber grommets into back boxes. Such a joy:tongue3:
Anyway as I always test circuits before working on them I found a dead short between Neutral and Earth but RCD holds?
RCD tests came back well within specified tripping times on x1 and x5 tests but RCD failed to recognise this dead short?
Anyone have any suggestions as to why this RCD will test fine but not do it's job as intended?
All testing was done with circuit completely removed from Consumer Unit. Faulty leg found between two sockets so removed and as said made ring into two radials, each on their own mcb (same RCD). Comment sticker left on consumer unit explaining circuits 2 & 3 both energise kicthen.
Kind Regards
1SC
The thing is what lessons should be taken from this well yep you have a low reading but at the same time it costs nothing to do some other tests as well even if you just jott them down a bit like a British Gas guy who tests a socket and says big problem here you have no earth but if he tested some other sockets ie random he may have said this socket has no earth but the others are ok
I would suggest neutral on the faulty leg is interconnected with a neutral of another circuit (likely to be cooker). I am assuming you only removed the circuit in question to carryout the testing. Therefore leakage back through other neutral to earth at transformer. I would suggest removing faulty neutral and carrying out test between that and the neutrals of the other circuits on that RCD.
I've tested for borrowed Neutrals between other circuits as this is what I first suspected. Also, whilst the circuit was removed I tested for continuity of both Neutral legs to the main earth bar of consumer unit and nothing :thumbsup
Does it the circuit trip under load?
Nope, not a single trip and circuit has been under normal daily usage
Thanks for all your help everyone, much appreciated as always.
Erm, quite possibly?
So whilst the IR reading was low enough to require further investigation and rectification there may have been enough resistance between Neutral and Earth to not trip the RCD.
The thread title is "bizarre dead short"we will have to call you 2shortcircuit from now on :smile:
Your reading has only confirmed that you dont have a million ohms,add a bit of resistance of the cpc back to the met and its not that bizarre I would say for the rcd to hang on in there
That will be fine just write down for 'Design ' Electrical Trainee and Signed of by NICEIC supervisor ..Of course I am being flippant..? ' Tony Cable'..my autobiography I woke after 5 weeks from a coma...To find myself as an Electrician lol
It would seem you have hit the nail on the head.
The earth leakage is obviously working within the tolerance of the 30mA RCD therefore not tripping it however at a later date this could become worse and lead to nuisance tripping or the amount of leakage combined with that of other circuits could eventually step out of the tolerance level again causing nuisance tripping.
At least my actions of finding and rectifying the fault were correct and should eliminate any tripping of the device.
**** note to myself, Learn more, test more and understand more ****
Thanks again to everyone that has added their input, great forum.... I continue to learn more everytime I log on:thumbsup
Reply to Bizarre dead short between Neutral and Earth in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
