Bizarre fault today immersion timer | Page 2 | on ElectriciansForums
Discuss Bizarre fault today immersion timer in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
got a phone call from my brother at about 1.30pm to say his immersion timer had caught fire and completely melted.
I thought he was exaggerating so popped round to take a look.
And yep it had completely melted into a big ball of moulded black sticky plastic...:eek:
This timer was fitted when he had a new immersion fitted about 2 years ago (all electric flat).
I have replaced plenty timers that have given up the ghost , but never seen one completely melt like this.
Thought ....?
Impossible to check terminations as the whole thing was a melted big ball of black plastic
I just cut the abomination off and threw in the bin
Seriously man, first thing you do is take a photo to show the forum, if you’re going to stick around you’ll need to change that mindset - ‘just threw it in the bin’ - tuh, heard it all now!
Can anyone recommend a decent digital timer for immersion heaters ?
Horstmann make a range of good and easy to fit timers, digital as well.
I've found that you can't go far wrong with the old school Timeguard mechanical timers with the little silver pins to set on/off times with. [Used to be branded Smiths]. Although I've known the motors refuse to overcome the resistance of an 'on' pin and a number of years use.
Nope
I don’t mind plumbers to be fair
Apart from the dipstick who I paid to fix a leak in my bathroom that still leaked after he supposedly fixed it
He took my money and refuses to come back meaning I had to get another guy in
....don't tell me that meant you had to ring a plasterer,too?
...If it wernt for all yer bad luck - you'd have no luck,at all...;)
It won't have just suddenly melted, it'll have been festering for a good while, probably since it was installed.
That strange occasional smell they've had near the timer will have gone now.
After the leak in the wall was found and repaired properly by the second time by a legit plumber and not the badger handyman I used the first time , the wife then decided she wanted a new bathroom suite and all re-tiled.
And no I’m not joking...
The whole thing cost a small fortune in the end.
I didn’t mind paying for the new bathroom.
But paying the first plumber £200 to do a job which he didn’t do properly (it continued to leak) was the annoying part.
Just a thought but did the original installer use a timer that could handle the current? there are many timers that are designed for lighting and not for 3Kw continuous.
Reply to Bizarre fault today immersion timer in the UK Electrical Forum area at ElectriciansForums.net
