Bizarre voltage readings | on ElectriciansForums
Discuss Bizarre voltage readings in the UK Electrical Forum area at ElectriciansForums.net
G
Gossy
I have installed a new cooker supply to the new DB. The cable is a 10 mm T+E. It's on a 50 amp RCBO. (Big cooker!!) tested the cable and made put it in connector block and switched it on. I was getting 240v down live to earth which is correct but neutral to earth is was getting 40v. Then live to neutral I was getting 118V . I thought it was thought it was the RCBO but changed it three times and still read the same. When I connected it to cooker I get 240 v through neutral and earth as well as live and earth. What's going on???
Reply to Bizarre voltage readings in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E...
