Black cable off supplier's incoming cable? | Page 2 | on ElectriciansForums
Discuss Black cable off supplier's incoming cable? in the UK Electrical Forum area at ElectriciansForums.net
impish15
Trainee
Supporter
Bromley
Hi,
Any suggestions what this black cable is coming off the supply's incoming cable? Its a TN-S system, I thought it could be the earth conductor but the cable is black not green/yellow, plus it looks much smaller than 10mm2 plus there is already an earthing conductor coming off the sheath going to the MET.
Any advice welcome
Dennis
[ElectriciansForums.net] Black cable off supplier's incoming cable?
I've never had an issue with it outside. And it's been used by thousands of satellite and aerial installers over the years.
There must be different types, the stuff I have used has crumbled.
I just did a quick search on the internet and found some say its ok and some say to cover it in pvc tape.
There are different types one being rubber and one being PIB whatever that is.
Self Amalgamating tape is typically made from EPR rubber, EPDM rubber, butyl rubber or PIB (polyisobutylene)
Like this stuff isn't UV resistant
Must have been cheap stuff.
Never heard of covering it with pvc tape. The rubber layer formed should be sufficient.
I will have to tell the amalgamating tape around the junction box to the alarm cable in my field to the barn that it should not have lasted twenty years, naught tape. 🤣
You have a field and a barn? You kept that quiet.
What ever next - a former owner of property in mainland Europe?
This is the stuff that I've been using, I bought a dose of them a few years ago, I see that it was discontinued in 2019.
been searching for S/A tape in Green/Yellow. can't find any anywhere.
Do you have any news ?
Hi apologies for the delay, I have only got around to re-doing the test yesterday as caught up between jobs. I used my colleague’s tester and got 0.10 then I re-tried my Fluke considering the possible double nulling when I did the test previously and got 0.11 so looks like I might have double nulled when I did the test before. Thanks for the heads up on that
Reply to Black cable off supplier's incoming cable? in the UK Electrical Forum area at ElectriciansForums.net
A bit like saying plumbers makes good electricians. 🥴
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
